Hello.Some objects in my scene are semi-shaded even though there is no light in the scene.When I apply normal modifier, they turn black. When I add material, it does not change.I use max 2021. Thanks.
Solved by gurhany. Go to Solution.
Solved by dbtITadmin. Go to Solution.
Hi there, try adding a 'weighted normals' modifier to the object and collapse the stack.
May have to play around with the setting in there but that usually works for me
