3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Scene explorer display issues
4 REPLIES 4
691 Views, 4 Replies
I can no longer see my layers (there are quite a few) in Scene Explorer... all I get is the default layer and it is empty. If I click the toggle for list by Hierarchy all my objects are listed, but going back to layers reveals and empty scene explorer window. I've 100's of objects all careful organized via layers so this is a real issue for me. Am I missing a simple toggle or has something gone corrupt? Thanks in advance for your help.
Frank
max 2018
Frank
max 2018
4 REPLIES 4
@Alfred.DeFlaminis
Forgive me if I am not doing this correctly, I'm having some difficulty getting my head around this forum. I'm attempting to reply to my own message and tag you in it in the hopes that you can shine some light on my problem. I had drafted another post with links and a screen shot but lost it when I hit the Reply button so I'm trying again.
Here is a link to a solution but I do not know how to run this script... this does though show exactly what I am dealing with. Please have a look.  https://www.instagram.com/p/BhfuJBmnowoeCEQdOdwvwRDLDYMxkbDg8eXhgw0/
Additionally see the screen shot I've attached so you can see what I am seeing.
Thanks very much for any help you can provide... I need to get this solved asap.
Frank
@Alfred.DeFlaminis
Frank
CAMedeck
CAMedeck
Download the script that he had linked to, and save it somewhere on your computer.  In 3ds Max, find the Scripting menu on the top toolbar and choose Run Script.  Then navigate to where you saved the .ms file you downloaded.
By the way, Alfred is no longer a moderator here.  😞  But @hagen.deloss seems to be his replacement, and is doing a pretty good job of it, too.
Chris Medeck
Chris Medeck
hagen.deloss
hagen.deloss
Hello @Anonymous
Thanks for posting in the forums! From my understanding of your issue, your layer structure isn't appearing? Are you using Xref objects?
I noticed that you posted in this forum thread and I was able to help you out there, is this issue different/does the script linked in that thread not solve this issue?
What happens when you create a new layer?
I want to gather as much information as I can before proceeding so I can best help you 😄
Talk to you soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Hello @Anonymous
Talk to you soon!
Hagen Deloss
hagen.deloss
hagen.deloss
Hello @Anonymous
I wanted to check in and see if you worked through any of the potential solutions mentioned above? I would love to help out if you haven't found a solution to the issue.
It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Talk to you soon!
Hagen Deloss
Hello @Anonymous
Talk to you soon!
Hagen Deloss
