Is it possible to resize (make larger) the PATH MARKER for a spline? I know it seems like a trivial issue, but sometimes it is difficult to see if the PATH is quite long, and the viewport is zoomed out. The little yellow "X" becomes almost impossible to see because it is so tiny. This is an issue when trying to build a LOFT having multiple different corss-sections.
Thanks for any help you could give.
Dave
Dave
Solved by Fadhil_Farook. Go to Solution.
I doubt that this is possible. You can go to Customize > Preferences > Gizmos and try something there (which I did and that didn't help change the size of the gizmo/marker).
Well, thanks just the same for the reply!! Have a great day.
