I was having the same issue and found that my problem was that the object was linked to another object. Once I unlinked the object and Reset XForm, the bounding box collapsed nice and neat.
Hi, I'm having the same problem. Resetting Xform and attaching a small box to the offending item and then deleting it as an element hasn't solved the problem. I think this happened due to my use of symmetry which I had to use and collapse several times. I've tried doing this with it as an editable mesh and editable poly. Anyone have any suggestions?
No, no it was either blindness on my part or problems I have been having with 2017 and Nvidia drivers with a 1070. There were some lone verts that somehow stuck around but I never saw them until one moment I rotated the camera at a decent distance and there they were... Mental note, remember the remove isolated verts button. I'm just sort of coming back after a 10 year hiatus only to find not only have I forgotten more then I could have imagined, the interface is now both familiar AND different at the same time. Add on to that the increase in quality expected from you due to the changes in tech and it's a daunting set of challenges.
