I am trying to project the high poly detail onto the low poly mesh. I have unwrapped the low poly mesh, selected it and opened the 'Render To texture' box and I need to be able to select the 'Projection mapping' however, it will not let me, it also does not display the name of the low poly mesh in the 'Objects to bake' section yet I have selected the low poly mesh.
I use this method to project high poly detail onto low poly meshes all the time so I have no idea why this is not working suddenly. Any help is appreciated.
do you have a texture on your models? see if this video helps
Thank you for taking the time to reply but i have figured out the issue, Everytime i save and close 3ds max and then re open it the objects are frozen all i had to do was unfreeze them.
