I'm beginner to 3D max and I've been facing a problem since I've downloaded it. I was trying to connect two edges, but "connect" tool it doesn't work. and it doesn't do any action.
Any help, please?
Solved by 10DSpace. Go to Solution.
It's not clear from the screenshot which edges you are trying to connect. Are you trying to "connect" Box01 to Box02?
Just in case you're trying to do something that may be done in a better way, can you describe from high level what you are trying to do?
Sorry for inconvenience. Actually, I am watching a Youtube tutorial (https://www.youtube.com/watch?v=YOtuLU5K48w&t=44s) and following what he did. I am trying to connect the four red vertices (please, check the attached picture) but when I press "Connect" it does nothing.
@Anonymous
You don't have "edged faces" display (F4 is the hot key to toggle it on and off) on so I cannot really tell for sure, but one reason why connect would not work on those 4 vertices on the corners is if there is an edge along the roof line connecting the vertices at the peak of the roof. For Connect to work on vertices, there cannot be any edges between the vertices that would "block" the connect. Toggle edged faces on and see if there is an edge along the peak of the roof that is preventing the connect function.
