3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Problem with UVW map and geometric shape defaults
4 REPLIES 4
1178 Views, 4 Replies
I have a problem with the geometry mode.
Every time I go to create any simple geometric a problem occurs when it 'behaves' like its an imported AutoCad file (DWG, DFX) etc.
When I go to add a UVW Map onto this shape I am unable to change the length, width, height (please se attached jpg).
I have re-installed 3D Max 2015 and I have updated the Service Pack3 but it still goes back to this problem.
I also have 3D Max 2014 installed and in doesnt do this, please help (Im sure its something simple!).
Many thanks,
Robert
Many thanks,
Robert
4 REPLIES 4
PROH
PROH
Hi. The reason why you can't change these settings is, that "Real World Scale" is checked/activated. Uncheck "Real World Scale" and everything should work as expected.
NB - From what you describe (.. Behaves like imported ACD.. etc.) it sounds like "Use Real World Scale" is activated as default in your preferences. If you never us this, then go to Preferences and uncheck/deactivate it (Customize menu - choose Preferences - deactivate/uncheck "Use Real World Scale").
Hope it helps
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Hope it helps
3dsMax 4.2 to 2018
in reply to: PROH
Many thanks, that fixed it! I knew it was something simple.
However my geometyric shapes by default still being created in that (ACD) mode. I prefer to color my Geo Shapes (Vray - Mat IDs etc).
Anyway to get it back to normal?
Again many thanks,
Again many thanks,
PROH
PROH
Deactivate "Use Real World Texture Coordinates) in Preferences (General tab) and restart Max. Then UVW should behave "normal". This will not affect colors or mat ID - only UVW.
If my answer solved your problem, then please mark it as solution. This makes it easier for other with the same problem to find the answer.
3dsMax 4.2 to 2018
3dsMax 4.2 to 2018
in reply to: PROH
i have unchecked real world texture cordinate and restart it but still not working
