Hello I can't put image in 3ds max
Watched on youtube but on my 3ds max 2018 happens like this
I'm assuming that your image doesn't have anu tiling and that you want the photo
Mapped with one repetition with no tiling.
1- make sure in the Bitmap rollout the U and V tiling are set to 1 each
2- Apply a UVW Map modifier on top of the plane, choosing a Mapping style,
Planar and Box will work
3- Click Fit
Important Note: When you create the plane make sure that its dimensions have the same aspect ratio
of the image, otherwise the texture will be distorted. So if the image's height is 1.5 its Width, your Plane's Length
Should be 1.5 its Width, etc,..
