segments can from a solid model and or a part of a spline. Not sure which of the two you were talking about. For the outline, do you mean you want to create spline from a segment? Can you give us more idea of what you want
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Hi Ronel,
Thank you for reply
Answering your questions:
1. segments can from a solid model and or a part of a spline. Not sure which of the two you were talking about.
I meant segments as a part of spline
2. For the outline, do you mean you want to create spline from a segment? Can you give us more idea of what you want
Yes, I want to create spline from segments
Regards
check this
Hi @rimutaka ;
Unfortunately, you cannot give Outline command to a segment of a spline, but you can either outline the whole spline and delete the segments that you do not want, or you can simply shift + move the segment of a spline and create another spline that is attached to your main spline.
Kind regards;
