Hello. I am trying to create NURBS surface inside 3DS Max, lofting simple geometry (circle) along custom spline curve by use of NURBS "1-Rail" command.
The result of operation every time have an issue - surface always deformed betwen 2 first section-geometries.
Does any one know why that happening?
Neen to create exactly NURBS-surf for exporting it to CAD softwate.
Solved by leeminardi. Go to Solution.
The problem could be that the next to the last circle is rotated.
You would probably get better results by using the sweep modifier with the spline and a single circle rather than using loft.
Hello leeminardi. Thank you for your reply and given idea.
The problem was solved. I have edited first section-spline (ring) by using command Geometry->Reverse. It worked ideal and I was able to get nice suface and export it to Autodesk Inventor.
