Hello @Anonymous ,
You could try to use a different smoothing group for each side of the cut edges and make sure smoothing groups is checked in the turbosmooth. (Maybe already is.)
The old school method of controlling turbosmooths with extra edge loops is thankfully gone now. You could play around with opensubdiv and use creases and whatnot. Pretty great stuff all around. Another option might be to check out something like Turbosmooth Pro.
Last but not least you may have some luck with the chamfer modifer and some clever settings. (Min/Max angles, etc.) If you put that under a turbosmooth with the right settings it *may* help to smooth out that problem provided that the underlying mesh doesn't have any issues with alignment.
Best Regards,
Alfred (AJ) DeFlaminis
View Max Tips/Tricks Megathread
