Hi, I'm new to 3ds max and I'm trying to follow the viking helmet modeling tutorial. However, when I reach the step of mesh smooth, what I get is different from the tutorial. The bottom of the object is not flat. Can someone please tell me what is wrong? Thanks.
Before appling msmooth:
After applying msmooth:
Solved by Steve_Curley. Go to Solution.
Thank you Steve for your reply. The tutorial is from Autodesk's website:
http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Tutorials/index.html
I followed each step in the tutorial but couldn't get a flat bottom after applying msmooth.
I used 3ds Max 2013 student edition.
I try to upload the pictures again.
This is what it looks like before applying msmooth:
And this is after:
And in the tutorial, it looks like:
"Refine the Shape" Step 3. You failed to remove the lower section of the sphere.
Thanks for the extra details and images - much easier to see the problem 😉
