Hello Everyone,
I'm very new to 3Ds max, and I need to make a model of this coffee maker in 3Ds Max.
What should of methods should i use to model it? techniques? The more specific the help the better! I really appreciate it...
thanks in advance..
Mfarny
Solved by Steve_Curley. Go to Solution.
thanks for that, but i really don't have a lot of time at present, and was hoping for a more specific breakdown to guide me.
Ok, fair enough.
Not trying the easy way out, or being ungrateful, I should elaborate.
What i was wanting was more of the types of tools and techniques that could be used to point me in the right direction, that's all.
I've had a look on youtube and so on, but was really wanting more guidance to specifics like "for the top lid, propbabably i would start with a poly blah blah, then extrude. As for the handle, try a box and then manually bend..."
anyway, thanks for taking the time to answer my question..
cheers..
Thanks Steve, that's billiant advice!
I've actually got one of these in my kitchen, and i've taken a load of photos of it, from many different angles.
It comes apart in 5 pieces, so probably i'll just try doing each one individually.
thanks again!
p.s - I'm aussie, so mm is fine with me!
