3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Mesh combining for 3d printing.
2 REPLIES 2
matt.wilmot
656 Views, 2 Replies
Hi guys.
I am looking for a way to combine multiple meshes together that become a single stitched mesh with a single element. Not one mesh with multiple elements.
I have tried using pro-boolean and Boolean in max and it kind of makes a mess of it.
I normally would use Dynamesh in Zbrush, which works pretty much perfectly at combining all objects together as one with no gaps and good topology.
Any help would be greatly appreciated.
Cheers
Matt
2 REPLIES 2
jamesw
in reply to: matt.wilmot
Select first mesh then use attach and pick the second mesh. It will join them together. Once joined select all the vertex and weld them, this should combine into one element.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
Cheers
jamesw
in reply to: jamesw
Was this answer of any help?
