3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Measure Utility
8 REPLIES 8
Message 1 of 9
1211 Views, 8 Replies
Measure Utility
How do I export the dimensions from the measure utility?
Preferably in MaxScript
8 REPLIES 8
Message 2 of 9
leeminardi
If you want the distance between 2 points you can use the following in a Maxscript.
e1 = pickPoint prompt:"\nPick 1st point" snap:#3D
e2 = pickPoint prompt:"\nPick 2nd point" snap:#3D
vlen = length(e2-e1) -- vector length from vertex 1 to 2
xlen = dot (e2 - e1) ([1,0,0])
ylen = dot (e2 - e1) ([0,1,0])
zlen = dot (e2 - e1) ([0,0,1])
format "distance = %, dx = %, dy = %, dz = % \n" vlen xlen ylen zlen
lee.minardi
Message 3 of 9
in reply to: leeminardi
I don't need distance between 2 points, I need to export the 'Dimensions'
the measure tool calculates (a rectangle for any shape) to a variable via
maxscript
Message 4 of 9
leeminardi
Can you give an example of " the 'Dimensions' the measure tool calculates"?   The Measure Tool on my copy of Max gives the distance between 2 points as well as dx, dy, and dz.
It is not clear what "rectangle" you refer to.  E.g., what would be the rectangle for a teapot?
If you are looking for the bounding box coordinates you can use:
$objectname.max
$objectname.min
lee.minardi
Message 5 of 9
I attached an example to this comment
Message 6 of 9
leeminardi
It looks like you want the dimensions of the object's bounding box not to be confused with the dimensions of the object.  You can use the two points of the bounding box to get those three values.
lee.minardi
Message 7 of 9
And how do i get to the Bounding box's dimensions with MAXSCRIPT?
Thanks so much
Message 8 of 9
leeminardi
There may be a more elegant method but this will give you the same output as Measure.
Determines the bounding box dimensions in world coordinates
of the select object lrm v1 10/10/201p */ obj = selection[1] w = (matrix3 [1,0,0] [0,1,0] [0,0,1] [0,0,0]) bb = nodeGetBoundingBox obj w pmin = bb[1] pmax = bb[2] dx = pmax.x - pmin.x dy = pmax.y - pmin.y dz = pmax.z - pmin.z format "\ndelta x = %, delta y = %, delta z = %\n" dx dy dz
lee.minardi
Message 9 of 9
Works like a charm! Thanks
