OK, after some assistance yesterday, I've been able to create my terrain and an extruded object to use as ProBoolean primitives. Attached is a screenshot showing the two objects and the MAX file for scene.
What I'm after is two fold. I need to slice the red object out of the blue object and (with a clone of both objects) gather a piece that represents the intersection of the two. Basically creating a grove and the corresponding filler piece that I can then use to show the hillside in different stages of mining operations.
Plan's all laid out.
Well, I select one of the objects (doesn't matter which) and commence to create a ProBoolean compound object. That step works, then I go to select the other piece to start the boolean operand and
BOOM!. Max blows up - crashes to desktop giving me the option to save my work. Since nothing really happens, saving would be a waste of time/disk space.
I'm wondering if anyone else would have the same problem with my file. If not, I'd be curious if anyone could find fault with my model and give me guidance as to how to fix the issue.
Any help appreciated.
15376_1Mg0Av51QN6vNnDMmMeH.zip
