Hi, i have 2 simple box like this image below, they've both been unwraped uv, but the size of the uv are not proportional (u can see the size of the square in checker texture).
I know that in unwrap uvw, in Tools -> rescale cluster can fix this automatically, i've tried this but it seem not work. Here is my issue:
Pls help me, thank you so much!
The problem is that the two unwrapped boxes are not the same size in the UV editor. The two unwrapped (green) shapes need to be the same scale. This can be done manually as well.
Just out of interest, if you are just UV mapping simple boxes why are you using Unwrap and not the UWV map modifier?
