I've just performed a boolean intersection of some sort and I'm struggling to figure out a solution on how to weld the verts in a way that the two objects are linked via vertices. I've already attached the geometry - this is more of a topology issue.
Any tips would be appreciated.
Pictured below:
Did you try to use the "weld" or "target weld" option in "Edit Poly" Vertex tab?
