3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
I have an edge attached to 3 polygons.. I thought this wasn't possible!
3 REPLIES 3
464 Views, 3 Replies
Hi folks. I have a model with an edge that is attached to three polygons. According to the docs, this shouldn't be possible. The reason I noticed it was because of some strange UVW unwrapping I saw after defining my seams.
I'm going to try and detach one face and resolve the issue, but is this a bug, or is this a legal object? If so, what's the best approach to resolve this? Maybe edge splitting or something? I'm looking into those options now.
Best regards,
- Sean
Best regards,
- Sean
3 REPLIES 3
Are you sure it is attached to all three? Try moving a vertex at one end to see.
Thanks for the reply! Yes, I checked that. In fact, I started off by selecting one vertex, verfying the modifier panel showed only 1 was selected, and confirmed the behavior when I moved it. I have since sliced up the geometry to correct this oddity, but it definitely happened. I believe I used the 'target' vertex tool to connect some of the polygons which may have led me to this situation. It led for a strange UVW unwrap, so I was interested if anyone else had encountered this. (This is with 3ds Max 2015, latest patches, BTW).
Cheers!
- Sean
Cheers!
- Sean
This is strange. I tried to replicate this. The verts will of course weld at one end of the "edge", but won't weld the verts at both ends, which would make it a single 3 way edge, as opposed to two coincident edges.
