3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
I cannot scale these edges apart?
4 REPLIES 4
2585 Views, 4 Replies
Inspired by some of Autodesk's early tutorials I have decided to model a jerry can as an exercise. However, as I try to scale this group of edges from the centre to buff out the sides of the jerry can to give it shape I am not able to, I pull on the gizmo but nothing happens? I am new to the 3DS Max environment, is something wrong?HELP2.PNGHELP1.PNG
Tags (3)
4 REPLIES 4
irishman_team_kilber
use the ring tool and that will ring all the edges of the lines you have selected and then you should be able to move them, but this mite change the form of your box
what i do is create box convert down and then seleced edges use ring this will select the ring around the box for example use the connect selecting box and add two segs for example and then use the pinch this will pull the edges apart when you increase the number of the spinner
Fadhil_Farook
You have to change the pivot point for the scale tool mate. From your screenshot, I can say that currently its set to PIVOT point. Change to Selection Center. See attachment
Eznaex
Oh no, I do this all the time by accident. All you have to do is while you have the edges selected, control + click on the vertices in your editable poly to select all vertices on them edges, the gizmo should then be in the centre and you can scale.
Sammionahi
in reply to: Eznaex
Your response just saved me years of pains, its easy to scale edges together and apart in other 3d programs and it seemed impossible in Max....This is a lifesaver. thanks
