Announcements
How to solve broken vertex/faces in a model?
Hi! There's a way solve this "automatically"? I searched on internet but I couldn't find anything.
Thanks in advance!
miledrizk
First we need to make sure all vertices are welded,
That means no 2 vertices overlapping at the same place,
To do that, go to vertex subobject level, select all vertices, then in Edit vertices rollout
Find Weld, click on the small rectangle on its right and choose a small value like 0.003
And click Ok.
Weld VericesWeld Verices
Now, to fix the broken look, go to Polygon subobject level, select all polygons,
Go to Polygon: Smoothing Groups rollout, keep the default value on 45 for and click Auto Smooth.
You might need to increase that value from 45 to a bit higher value if you still seeing some broken faces
Smoothing facesSmoothing faces
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Thanks a lot!
