Show only
Search instead for
Hi! I wounder if there is a way of making a Torus Knot spline. One way I was thinking about it to use a plugin to make a spline out of the Torus Knot geometry, but the one I can find is out of date (like 2003). Is there other ways?
You could - create a torus knot (extended primitive) - collapse to editable poly - go to subobject edge mode - select an edge which runs along the length and click Loop - then do Create Shape from Selection
... but this will just be a plain spline... no parameters like you get w/ the torus knot object.
