Announcements
How to increase the thickness of Arc?
I have made a cylinder as a teac cup and an arc as the handle of cup. Can some body guide me how to increase thethickness of Arc?
I am using 2011 3d Max.
Zulfi.
Select the arc, in the Modify Panel open the Rendering rollout. Check Enable in Rendereer and In Viewport. There are more settings for shape and thickness.
For more control, add a Sweep modifier instead. You can choose from a selection of section shapes, or use a custom shape, for example an elipse.
Thanks I am to do it through your guidance. Modify tab->Rendering rollout: Check Enable in Renderer: Check Enable in viewport: Assign value to thickness.
Zulfi.
