3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How to create this parametric object in 3ds max
5 REPLIES 5
qendri_oglock
631 Views, 5 Replies
Hi everybody ,
I need help creating this parametric object in 3ds max,I watched some tutorial on youtube but all are in different shape ,not like this one that I'm doing .
If anyone would help me ,I will appreciate that .
Many thanks
5 REPLIES 5
wernienst
in reply to: qendri_oglock
Interesting question.
My first attempt was creating a structure grid by drawing 2 spline objects, then use the Cross Section Modifier. Then I removed the original splines and added a Sweep Modifier.
It looks quite good, but the elements are not well aligned.
My second try was creating just one plank, then animate it so that it described the desired form. The I used the Snapshot tool to generate the final structure.
In the third example, I added Noise Controllers to the transform path.
qendri_oglock
in reply to: wernienst
Hi ,
Thank you very much for your time and help .I appreciate that 🙂
Can you send me the 3d model of the first one please ?
I think that's the right one
qendri_oglock
Can you do this one too? Is this difficult to create
wernienst
It's just a variation of the third sample. Here is a file for experiments. Remove the results, unhide the base objects and try by yourself!
qendri_oglock
Thank you very much for your help .I appreciate it
