3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How can I perfectly import cad plan to 3ds max so that I do not have to fuse and weld most of the vertexes
2 REPLIES 2
viz3djr
322 Views, 2 Replies
In case of masterplans ,many vertexes needs fuse and weld in 3ds max,Is there any way to avoid this time consuming process
2 REPLIES 2
CAMedeck
in reply to: viz3djr
There should be a Weld option when you import the DWG.  But if the vertices are not close enough, then it's just a poorly drafted DWG (which happens).  There isn't much you can do in that case, other than select all the vertices in a particular spline object and Weld, adjusting the Threshold to suit.
Chris Medeck
viz3djr
in reply to: CAMedeck
Thanks a lot for the solution.By default that option was off ,I changed it and now it is working perfectly.Saves lot of time hereafter
