I need your help urgently. I 've created a road with these factors in the screenshot but I want to make it smoother. I cant make a new road since I've already animated with it. Does someone know how i can make it more smooth?
@Anonymous
If by "more smooth" you mean that you want to smooth out the sharp edges in selected areas of the road, then you can convert the "RoadGeo" to an editable poly or add an edit poly modifier to it, select the edge(s) that go across the roadway with a sharp corner and Chamfer it. You can adjust the number of segments in the chamfer to get the desired smoothness and the amount of Chamfer. (It is not clear why you have the Path Deform WSM binding to the RoadGeo vs applied to the car ? Typically, you want to animate the car along the path.) Anyway, you can smooth the edges of your road by using Chamfer.
