Can someone convert this attached .max file to .obj/.stl/.fbx??
Thankyou IA
Thankyou IA
Here's a .zip file with your 3 format. I recommend using the FBX.
You still have a lot of work to do on this model 🙂
Note that the original had missing materials and textures, it's why those files are meshes only.
THANKYOU 😃
GODBLESSYOU
THANKYOU 😃
GODBLESSYOU
I think i just forget to attach these files. I don't even know that these files acts as Skin. Do check these. If they help, Can you please give me skinned 3d model(in .obj/.stl/.fbx)....
Attaching all the files that i downloaded as zip
https://drive.google.com/drive/folders/1cHHBOY9-wxaZgCmhq2H5i3G5Ih7YWi6m?usp=sharing
waiting for your answer
*fingers crossed*
*fingers crossed*
I have attached two screenshot. The first, missing external files, is the missing images in your file.
The second, is the UV mapping of this model.
Unfortunately, there is nothing more i can do. You will need to find or recreate those textures. And most importantly, you will need to remap the uv's.
Great, I appreciate your efforts. will take a look on your advices
Thankyouuuuuuuu 🙂 🙂
Thankyouuuuuuuu 🙂 🙂
Hi EP,
is there any way you can do the same for me?
https://www.dropbox.com/s/09ozc3cutsgkfb2/space_man.max?dl=0
Hi EP,
In the zip, you have an fbx and an obj file. If you need the rig, you must use the fbx file.
