I have 3d max 2011 installed on my system. I am trying helmet example in the tutorial. I am trying to extrude the Seam and rift faces of the helmet. But i cant see the Connect option in loops panel: What i am seeing is this:
I am also not seeing the Caddy Controls. Some body please guide me with problem.
Zulfi.
Solved by Steve_Curley. Go to Solution.
Because you're on Modify Selection and not on Loops. The Caddy Controls will appear after you click Connect on the Loops tab.
Thanks. Its working now. I am able to make the helmet. Now i am trying to make horns.
Zulfi.
