extrude in( local normal) make nonuniform extrude
i try to extrude faces like i do in maya
so this is the result in maya
  TzGgipr
this the result in max - please how can get extrude like i have in maya
and i use this in complicated scene so i cant modify edges/faces manually
#note: i found plug in fix extrude but it not support new max versions
  https://www.renderosity.com/mod/forumpro/?thread_id=2882641
please any help
don_3259
hi i tried to do this that is result you need ? just select face and extrude using local normal in extrude option...thanks
Autodesk Student Amassdor
Guest & Visiting Lecturer
Ali Sajjad
