3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
drawing a spline on adjoining walls
6 REPLIES 6
675 Views, 6 Replies
How do we draw a line on adjoining walls like in the picture (the red LED strip)? Please help!
6 REPLIES 6
leeminardi
leeminardi
Perhaps this video on ShapeMerge will help you.
lee.minardi
lee.minardi
in reply to: leeminardi
Thank you for the reply. Really informative video but didn’t really help with my situation ☹️  Attaching some more reference pics. I tried drawing a line and getting a structure using loft but it isn’t smooth. Also no idea on how to get two shades- black on top and white below.
leeminardi
leeminardi
It looks like just applying a bitmap with a Unwrap UVW modifier might do if you only want an image on the walls.
lee.minardi
lee.minardi
okay, i'll check it out. Have to learn what a  Unwrap UVW modifier is. This is my current render. Thanks again
If the previous suggestion did not work out then maybe you could try to actually create the lines and connect them on the walls themselves then select the lines and then use the 'create shape from selection' option in editable poly. try it with a duplicate object to see if it works out, this way you can the exact shape on the walls and be able to aline t perfectly since the objects pivot will be the same.
This youtube video helped me a lot, hoping it will be helpful to everyone out there 🙂
https://www.youtube.com/watch?v=hMcXhMFnB-4&list=PLDceQt8EFT2QaRir8O1ORwpfBp8jsWRKz&index=8&t=194s
Attaching my current render image as well.
