Hello All
I was wondering if there is any way we can drag and drop material among objects. Is there a script available to do so?
I usually end up creating palettes within the scene which is project specific. Since there are usually lot of back n forth as we do color jet 3d printing it could have been quite useful if I can simply drag a material from an existing pre mapped object to the target object that I want. It should take the material + bitmap + UVW map modifier on the object.
Below you can see a palette which I have created. Let me know if someone has this script.
many thanks
Solved by miledrizk. Go to Solution.
I made a script that will allow you to do what you're looking for,
Here is a demo on YouTube on how it works:
After installing it you can find it by going to the Customize menu, Customize User Interface,
Click on the Toolbars tab if you want to create a toolbar button for it, now in the Category drop-down list
Look for MiRi-Tools and you'll see in the Action section the script called "matchmaterial"
I recommend you download this updated version. I noticed a small bug in it, nothing important,
But in the previous one, sometimes, pressing Enter on the keyboard wasn't working, only the
Right-Click. So in this updated version, the Enter key will always work
Again I'm updating my script (hopefully the last time),
I saw another Bug, and that's when the source object has modifiers but without any UVW Map or
Unwrap UVW, the script fails to match the material. I know in your case you are sure to have a material
And a mapping tool but I'm trying to make my script more general, so please use this second update,
The script is created this evening so it's normal to have a few issues.
I love it. It's really good. Is there a way to drag n select when the match material command is working.
I tried to make the script simple and small as much as possible to avoid lots of bugs,
And I'm sure there are some left in special scenarios,
Now I'm doing some intensive tests with different scenarios,
I already caught one in a special case and I'm trying to reproduce it and fix it,
Currently, you can click the script while the material editor is open, you can drag
And drop materials onto objects in the viewport while the script is alive and ready for picking
Targets objects. It also works in some other scenarios.
Hi again 🙂
Yesterday I discovered a couple of annoying bugs while doing intensive tests on the script. The first one is when the user press Escape after clicking the script, this caused an error. Also, if the User already picked one target, then clicked The script again, that also was causing an error.
I'm attaching the newly revised version.
