I am a beginner in 3ds Max. I am using 3ds Max 2021. I find something difficult to understand.
When I draw a box from standard primitives I must convert it into an editable poly by left clicking on it and pick convert to editable poly to manipulate the geometry.
But I keep seeing in tutorials that some artists do not do that at all. They draw a box (standard primitive ) then apply 'edit poly' modifier and start working, and sometimes they apply 'edit poly' modifier more than once.
I wanna know -
1- What is the difference between left click convert to editable poly vs applying 'edit poly' from modifier.
2- Why applying 'edit poly' modifier more than once if I already convert in into editable poly?
Thank you.
