Hello, can someone please help me model this end condition of a tensile roof canvas, where the smaller radius is below the larger radius?
Thank you.
Solved by leeminardi. Go to Solution.
So it was just the application of two modifiers? I had never used "CrossSection" before. Thank you so much!
Yes, after applying the Cross Section modifier I noted that the direction of one of the splines needed to be first reversed. After the reversal some values for the surface modifier needed tweaking.
Good luck with your modeling.
