Hi
I need to create a surface from the curves attached bellow. In the next stage I will place a semisphere on the top of the horizontal circle. The entire surface will be like a church dome. Does someone have the slightest ideea?
I have tried with NURBS but I have zero experience about NURBS ... Is this the right way to approach?
Solved by leeminardi. Go to Solution.
Solved by truckexpert. Go to Solution.
You could create a sphere, and slice it with four planes on the 4 side and two planes for the top and bottom
Adding to @truckexpert 's excellent suggestion, center a sphere (within Hemisphere set to 0.5) of radius 1.414 (square root of 2) at 0,0,0 then position the slice modifiers at x=1, y = 1, another at x = -1, y = -1. and a third at z = 1.
