Creating a CLEAN ellipse within a plane?
I have a small box-like mesh which represents a playing card.
What I'd like to do is insert an ellipse within the upper-center (green area, see image below) of the mesh, without disrupting the quads of the mesh too much.
e2b71a503bc0431290ec9796ce52acc8
The image above depicts how the mesh looks before attempting to place an ellipse within the green area.
Here are the steps I've tried, but with rather poor results:
  1. Select a 3 x 3 (or higher) area of faces (See Example)
  2. Apply an Inset (Example)
  3. Delete the selected faces (Example)
  4. Switch to Edge Mode, and double-click the edge of the hole (Example)
  5. Open the Loop Tools (Example)
  6. Click the Circle button (Example)
  7. Scale the circle along the X-axis to form an ellipse (Example)
After following these steps, then shift-dragging & scaling the edge loop around a few times, followed by a meshsmooth, I was able to produce the following halfway-decent result:
d768281509b1475b89e084bf9f2270d2
It looks decent enough, but the topology around the ellipse is far too messy, and it screws up UVs when applying textures:
d1fd3a5557244b0f812a458d90506a50
... So I was wondering if anybody had a better solution to this? What can I do to make the topology cleaner, and still produce a relatively equal result?
Thanks!
Daf
As with most situations there are many ways to do this. This is what I would do. First go get the Loop regulalizer - great script!
http://www.scriptspot.com/3ds-max/scripts/loop-regularizer
Create your plane - just need 4x4 subdivision. Convert to editable poly. 1.jpg
Scale the selection to avoid overlap of edges - then scale to create the elipse shape as needed. 4.jpg
There is your ellipse and with clean topology. 🙂
The deges can be moved prior to running the script to accommodate the size and location of the ellipse as needed.
Hope this help! You will probably get more suggestions as well.
Thanks!
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
Daf
Here's a video that helps explain the functions of the Loop Regularizer - even if you don't use it for this instance it's a great script to have on hand. 🙂
https://www.youtube.com/watch?v=kACvVCB2_pI
3DS Max 2020.3
I had to select a larger range of faces than just a 2 x 2 area in order to get better results, but this is what I ended up with:
f9e0fb437a944ef3b53d00b98deba03b
... And after adding the ellipse's border and applying a turbosmooth, I got this:
e79c9a49d55e4847b8fac2c57aa314b9
... Still not perfect, but definitely a massive improvement! Thanks!
