Create surface from transversal and longitudal splines
yanishristov
yanishristov
Please help me to create the ship surface from transversal and longitudal splines (and also the profile) . I did it before with shell modifier but I need to be just surface not having a volume. I guess need to normalize the splines ( say a knot every 5 cm or so, all running in same direction). I am willing to give you the splines and give me back the surface.
Replies (7)
yanishristov
In Rhino there is a tool to create surface from network of curves where you show the first and the next curves in one direction then in other direction, but here in 3ds max what is the analogy
CAMedeck
There is a modifier called Surface that will 'cap' any triangles or quads in a single Spline object.  So if you attached all of your spline object above, as long as there are vertices only where lines cross, it would create a complete surface.  Depending on how it is built now, you might want to look at using Cross Section (either the modifier or the tool within the Editable Spline object) to connect the spline sub-objects.
Chris Medeck
yanishristov
Thanks for the answer, the Surface modifier cant make it work as all the splines are created independently ( even after Optimizing or Normalizing). Cross Section works but only using lines in one direction ( this tool creates the lines in other direction). I am looking for a way to make a mesh with all this lines.
leeminardi
It looks like you have half-breadth curves (top view, constant z), and body lines (right view, constant x).
You might consider making two separate surfaces for these two sets of curves and then make buttock curves (front view, constant y) by slicing the two surfaces.  This would give you a feel for the deviation between the two sets of curves. You will probably find that different areas of the hull are better defined by one set of curves over the other.
I don't think it is worht getting too focused on the accuracy of the final surface as Max's limited precision is not aimed at precise modeling.  Max is best suited for generating good images not data for an engineering analysis.
lee.minardi
yanishristov
It is not possible to create complete surface using both sets of curves. @leeminardi  was right to use either one or the other set, I split t he model the nose, the bulb, the long body, and aft part on 3 different parts to create the complete surface piece by piece. I did on every piece the  splines in one directions attached to one and cross section on spline level ( normalized first to either 50,40 or 30 knots and make sure starting from one of the sides - colapsing the stack or spline select) and then Surface modifier. Now have to stitch them.
Attach All your lines together as one line then Use Surface !
domo.spaji
It is possible. But, luckily, unnecessary because Cross Section (followed by Surface mod.) will create second set of splines instead we detaching (maybe/probably all) splines to separated obj. and attaching those again in desired order to single spline obj.
Anyway, keep splines and surface as simple as you can and define curvature/smoothnes at the end/top of mod. stack with something like Turbosmooth mod.
P:S.
"Max's limited precision" have nothing to do with anything, symplest way to say.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
