Good morning
I have a beginners problem. I am trying to extrude a logo (images) but only the R is closed on both sides. The other letters remain open. When I try the modifier "CAP Holes" the A isn't working properly.
I tried with the Logo as editable spline and editable mesh, the result remains the same.
Can anybody help?
Thanks a lot!
Jakob
It usually means that your letters are not closed loops. As a potential quick fix you can try selecting all vertices and performing a Weld with the tolerance set to a very small or 0 value.
I'm guessing that you have 2 vertices that are overlapping on each letter.
