3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Chamfer on Joint
0 REPLIES 0
Message 1 of 1
lizGYM66
196 Views, 0 Replies
Chamfer on Joint
Noob to 3DS Max here.
I have an export from Revit which contains curtain walls which I want to apply a chamfer to the edges of.
How do I avoid the following (best see screenshot) ? In this example to sections have been joined together using the Attach command. There are many of these, so wondering if there's some form of auto solution?
As far as I know there isn't a way in Revit to make this joins a single continuous piece, hence why I need to join the geo after wards.
Thanks in advance!
0 REPLIES 0
