Hello, you can see the pink and green chain parts. When i export(.FBX) the whole hydrant model to use it in unity or where ever, the pink and green chain parts are not there, only the names are exported.
So what can i do to export everything correctly?
Hi Friend..
I think your chains are splines.
You need to convert them into poly or mesh because unity does not accept splines.
Hope this will help..
Thank you
Hi
@Anonymous if you find this as a solution, please mark this as solution.
Thank you.
