Cannot move selection
marshallSUYQT
marshallSUYQT
I ran into an issue where I cannot move my selection. I am able to move individual objects, but when I select multiple objects I cannot move in any direction. I am able to rotate however.
if this helps I have f12 set as my move/transform tool, usually it shows options to move in xyz but now it's only showing xy. Not sure if its related but both happened at the same time.
Please help if you can, thank you
RobinBall6995
Here's a few things to look at:
Maybe check the coordinate system isn't set to Screen.
Check the transform center. If the objects are linked to one another, or all to a common parent, then some center options may not work.
Have a look at the Link Info under the Hierarchy tab. You may have an axis locked on one of the objects.
BenBisares
Autodesk Support
Autodesk Support
I would also check if the Position Controller on one or more objects are set to something other than "Bezier"
Ben Bisares
