3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Can't Dimension to Circle Edge
5 REPLIES 5
620 Views, 5 Replies
Trying to model a Ying yang with 2 seperate halfs, With a gold beveling. However when the edging comes together it always loses the gold edging either at the top or in the middle. Tried anchor points with element. bevel changes, extrusion changes, none seem to fix it. Any help would be useful.
5 REPLIES 5
jeff
Can you post a pic of just the black half of the symbol? Might help narrow down the issue.
Max since 1992 (3d Studio) · Win 10-64 · Wintel workstation · 64 GB RAM · nVidia Quadro RTX 4000 · BB render garden via Deadline
in reply to: jeff
jeff
Maybe you've figured this out by now (I'm not on the forums regularly), but it looks like what I would expect for a bevel: consistent (gold) edge all around. If you are not getting what you desire, it's probably something other than the bevel modifier that is not doing what you expect. Co-incident faces, maybe?
-Jeff
PROH
in reply to: jeff
Hi. Looks like the white and black parts fits perfectly together, leaving no space for the gold bevel. You need to offset the base shapes inwards with the exact same distance as your bevel "thickness".
Hope it helps (if not to late)
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
