I'm trying to connect two borders on the same object (picture 1), but bridging doesn't seam to work, as you can see in picture 2 it only makes some horizontal polygons.
If I choose 2 edges on the borders and try to bridge them, picture 3 is the result. Does anyone know what the problem is?
Solved by Steve_Curley. Go to Solution.
Hi good sirs,
I also have the same problem but i don't know if i flipped it or not. i'm a beginner in this field.
i'm using 3ds Max 2013, and i am making a gloves, i already welded the part of the thumb and as i tried to target weld the other parts, it does not work.
my professor suggested to restart my computer, so i did. but when i continued again, it's still not working.
So i am wonder why and how can i fix it? i'm hoping that ill get help cause this is part of my project sir.
thank you good sirs.
1- Go to Polygon sub-object level
2- Select the fingers polygons
3- Click Filp in the Edit Polygons rollout
4- Try Target Weld Again
Hi there! If I may chime in for a moment; every face that comprises a form has two sides: it's "Front Face" and "Back Face". Polygon faces, by nature aren't two-sided, so keeping in mind their facings is important when fusing verticies or bridging faces.
You will see this behaviour much more clearly when using the "Quick Align>Normal" tool as well; when you select the "Align to" geometry, you'll see a small blue arrow indicating it's resultant vector or angle (think of a ball bouncing straight back from the ground) which tells the selected geometry which way to point since (in 3d space) there wouldn't be any other way to instruct the two faces to join.
Two sided faces can also aid materials as well. I believe 3ds's bundled "2-Sided / Front-Back Material" can show you separate maps based on the face orientation which can be useful when sectioning geometry or for neat effects.
If just the bright and dark red faces aren't good for troubleshooting, try using xView (It's a life-saver for me!). If you go to: "View>xView>Face Orientation", it will highlight all reversed faces much more clearly even during edits which will help you clean up your geometry for sure-fire welds, good luck! 🙂
