WINDOW 10
3DS MAX 2018
ENCLOSED: IMAGE FILE, 3DS MAX
I JUST CLICKED "BRIDGE" WITH TWO POLYGONS.
AND THE GREEN COLOR OF OBJECT BECAME BLACK(LEFT).
THE RENDERED IMAGE IS SOMEHOW DIFFERENT FROM THE OBJECT AT THE SCREEN.
WHAT SHOULD I DO?
Strange! Everything is fine in my screen, and I did the same thing as you did.
Thanks for your trouble.
Actually I'm asking about a seat or cushion, a part of chair, not a whole frame of chair ...
Well, I like your work though.
It seems that the Polygons Normal has reversed, Try Editable Poly -> Element (Selection Mode) -> Select Object -> Flip (Button Under Edit Element Rollout).
