Solved by irishman_team_kilber. Go to Solution.
once you match the system units and display units in 3ds max to the same units as you have in the file you are trying to import then the scale should be the same. if you attach the file with the system units & display units you used to model it in the other 3D program then someone will able to help you to see if they are getting the same problem.
I'm sorry for the delayed answer... I chekced again all the scales and so son, but I can't figure out what's causing my issue. In the rar file you will find the model (a collider of a car for a simulator) and some screens of my unit setup and what i see importing and exporting the model (In the inport info the model is marked as built in centimeters). I also tried importing with the Automatic box checked, but my scale factor doesn't want to show up. Thank for the support!
