Bitmap Resolution Material Issues
brad.saliga90
brad.saliga90
When I added my bitmap material to a plane primitive, the textures resolution on the edges of my grass are pixelated. My viewport texture resolution is already set to 2048. I can't figure out whats happening, is my alpha bleeding over the edges? My video card is GTX 1080, which shouldn't be the issue.Capture_material.PNG
rendermaster
check this link:
https://forums.autodesk.com/t5/3ds-max-forum/max-2017-how-to-increase-texture-map-resolution-on-the-...
and also this:
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-d...
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
brad.saliga90
Thanks! I actually figured out what was wrong. My Padding for selected objects was too high in the render to texture dialogue window.
