3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Bitmap only shows base color and not texture on editable poly
2 REPLIES 2
1108 Views, 2 Replies
I am trying to apply a bitmap onto the face of an editable poly but the only thing that shows up is the base color of the map. The bitmap works on other polys but when I try applying it to this specific one it doesn't work.
2 REPLIES 2
10DSpace
Did you apply a uv map or uvunwrap modifier on the editable poly?  Without uvs the map will not show properly.  A screenshot of your mesh and the modifier stack would help to understand your issue.  You also have to enable show texture in viewport in the material editor.
in reply to: 10DSpace
Thanks! I added UVW map and it worked!
