3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Bevel edge of a complex model
7 REPLIES 7
Message 1 of 8
trinitifx
2104 Views, 7 Replies
I have a complex model that is basically a short tube with an angled cut in it.
The cut ends are then coiled inside.
I need to bevel the outer edge.
I have tried to chamfer it but it is not nearly as sharp as I need it to be.
I also tried to just select all the outside polys and scale them down (that should give me a great bevel), but I can't figure out how to scale them uniformly based on their mesh position.. Right now they all scale together, meaning the polys on the cut scale IN toward each other..
7 REPLIES 7
Message 2 of 8
in reply to: trinitifx
It should be OK using a chamfer modifier and set it as
image.pngSoft chamfer : tension 0.5Soft chamfer : tension 0.5Hard chamfer -tension 1.0Hard chamfer -tension 1.0image.pngVariations...Variations...
Message 3 of 8
blakestone
You could also simply extrude the faces you wish to chamfer just a little bit and then apply the chamfer.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Message 4 of 8
trinitifx
in reply to: blakestone
Thanks guys.
The problem is, I need much more of a 'bevel' than a 'chamfer'..
See attached- I just grabbed the lower inside edge and pulled it down. I need this much of bevel.
Here is the other problem- the INSIDE section should be the extents of the model (this is for a 3D print), I really need the OUTSIDE beveled inward/smaller..
I would have created the shape as I needed it before warping it, but it warps the bevels out of shape.
Message 5 of 8
blakestone
Instead of using bevel you could extrude and then remove the unwanted edge and rotate (if required) as shown below.
Message 6 of 8
bevel based in local normal in selected faces should work
Message 7 of 8
trinitifx
Those solutions work great, except I can't extrude or bevel OUTWARD and make the model any taller than it already is.
The outside edge needs to bevel in/smaller, not the inside edge extruding/beveling out/larger.
I will look at removing rows of edges/verts and see if that works.
I thought adding a taper at the very beginning would work, but the model still distorts too much at the points.
Message 8 of 8
Bevel and chamfer are considered some times the same.
But in Max
  • Chamfer carves the edges
  • Bevel extend the edges
It seems that chamfer is what you are looking for, but I quite don't understand you.
In any case I have already sent you an example of chamfer. You design how looks. My examples were simply basic variations:
Technology Administrators
