Helloo
I am using the bend modifier, but I am not able to bend it the other direction, I tried all the Axes ( in the image its x axis)
and when I tey y acix it goes bending on the same plane.
Help please
Solved by krystian.slusarz. Go to Solution.
In which direction do You want to bend it? If any of the option in modify panel dont work for You, You can manualy transform the modifier gizmo to fit your need. I've added a video - hope it helps
