I'm trying to make this extruded face a sharp point. What is the most efficient way in doing so? Thanks!
Solved by leeminardi. Go to Solution.
If you are trying to make them into a single point (1 vertex); in vertex sub object mode, select all those vertices, and in the Edit Vertices rollout, click the Weld Dialog button, the little icon next to the actual Weld button. Raise the tolerance until all weld to a single point.
If you want it to be more like a chisel tip, you could weld each side separately. Even do one more extruded before that. Alternatively, connect the center vertex on each side together so you have a center line, then nudge that up and tweak the other nearby vertices to get the look you want.
Set the weld distance for the vertex sub object to a value greater than the current distance between the vertecies then click weld.
