I am trying to perform what should be a simple operation. I have a collection of groups which I applied a symmetry modifier to and I am trying to position the mirrored half in the proper position. I can move it with the 3D arrow tool but I can't move it precisely enough to get the X axis exactly at 0. So I try to use the Absolute transform type in.
So I type "0" in the x box of absolute and press enter. It does not set the value to 0, instead it increases the current value in the box. Next I tried pressing the down arrow next to the box to lower the value to 0. Well pressing the down arrow increases the value, and pressing the up arrow decreases it. When it gets to .002 pressing it again skips over 0 to -.002
So i cant enter 0 manually and I can't use the arrow to get to 0. How on earth am I supposed to position the X axis at 0?
Solved by leeminardi. Go to Solution.
Try deleting the symmetry modifier and then moving the pivot point of the group to the point of symmetry using vertex snap and then apply the symmetry modifier.
